I have a problem with my LHT65 probes uploaded to TTN portal and registered on Cayenne. The data I received was correctly on TTN and always updated, however no data is displayed on the Cayenne dashboard except the geographical position. Here compares the list of sensors but no data. Tried already to turn off and reactivate the probes, I deleted and added again, but nothing. Can anyone help me understand the problem? Thanks a lot!
There is no uplink sensor data received for all the above devices. Hence just the map widget since it is non-moving device.
Please go through the steps again as you might have missed something Cayenne Docs
I have done all the steps correctly, I don’t understand why honestly. I attach a stamp to show that the probes are present on the Cayenne and the data transmission by TTN updated.
there are only dev and app eui in the pic. So can you share a new screenshot where there is sensor data.
Also have you added the mydevices integration in the TTN ?
I have a similar problem with one of my sensors. Data are received in cayenne and I can see a graph of signal strenghts or Battery level, but somehow I get a message of no data available when I try to see the temperature data or the humidity data. The correct values appear in the data section and a single point is always displayed, but no graph. What can be wrong ? DEV EUI is:A840419F6182722D
