Weather Station 2019 is a device to monitor temperature and humidity, that sends all the results to the
Cayenne server with LoRa radio modulation. Weather Station 2019 is built around an Arduino MKRWAN
1300 board.
It’s powered by an Ansmann 3.7V 5200mAh battery connected to Microchip MIC5201 3,3V fixed voltage regulator
in order to guarantee low quiescent currents.
The chosen sensor is I2C interface version of SENSIRION SHT35-DIS. It has a
resolution of ± 0.1% ° C and ± 1.5% RH. SHT35-DIS consumptions are 45μA in idle
state and 6mA in measurement. It’s assembled on a special PCB and placed into
waterproof cap.
Weather Station 2019 is wired inside an Hammond’s Polycarbonate box with 160x90x60,5mm dimensions
and IP66 protection’s degree.
i am using a node mcu, ESP8266. and i want to track the device with the location widget, like the map on the screenshot. but i cant find it. how can i use that widget?
This example shows how to connect to Cayenne using an ESP8266 and send/receive sample data.
Steps:
1. If you have not already installed the ESP8266 Board Package install it using the instructions here: https://github.com/esp8266/Arduino#installing-with-boards-manager.
2. Select your ESP8266 board from the Tools menu.
//#define CAYENNE_DEBUG
#include <DHT.h>
#include <DHT_U.h>
#define DHTPIN 5
#define DHTTYPE DHT11
DHT_Unified dht(DHTPIN, DHTTYPE);
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
unsigned long lastMillis = 0;
#define VIRTUAL_CHANNEL 1
#define ACTUATOR_PIN 4 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
dht.begin();
sensor_t sensor;
//Publish data every 1 seconds (1000 milliseconds). Change this value to publish at a different interval.
lastMillis = millis();
sensors_event_t event;
dht.temperature().getEvent(&event);
Cayenne.celsiusWrite(3, event.temperature);
dht.humidity().getEvent(&event);
Cayenne.virtualWrite(2, event.relative_humidity, "rel_hum", "p");
CAYENNE_OUT_DEFAULT()
Cayenne.virtualWrite(20, buffer, "gps", "m");
//Cayenne.luxWrite(2, 700);
CAYENNE_IN(VIRTUAL_CHANNEL)
int value = getValue.asInt();
CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL, ACTUATOR_PIN, value);
