I want to make a window air conditioner wifi capable. I can wire into the existing switches with relays to turn it on/off and set the temperature up and down. Now I want to get feedback from the a/c to see what state the unit is in. I want to do it by monitoring if the Cool LED is on, and if the compressor is running. The compressor pin goes to +.5 volts when it is on, 0 when off. The Cooling LED is 2 volts when on. I am thinking these could be monitored with an analog pin of either my Raspberry Pi or and Arduino MRK1000.
if you can get the reading on your arduino then you can send them to cayenne using:
if (reading < threshold){
Cayenne.virtualWrite(channel, 0, "digital_sensor", "d"); //make two state widget 0 indicating the ac is OFF
else{
Cayenne.virtualWrite(channel, 1, "digital_sensor", "d"); //make two state widget 1 indicating the ac is ON
