i set up a Dragino LWL02 on Cayenne Dashbaord and i don’t even get RSSI.
The funny thing: Another Dragino which is nearly the same, the Dargino LDS02 works perfect.
Can i somehow debug this?
Greetings
Olaf
Greetings
Olaf
can you share your DevEUI.
Any News?
there is no data received from the deveui. check if you added the cayenne integration in NS.
Hi Guys,
i have the same problem with the dragino lwl02 water leackage sensor.
Webhook in thethingsnetwork done like with all my other lht65 devices.
i can see data in TTN console
I added payload decoder like i did with the lht65 which works fine
but no way to get any data from the lwl02.
my testdevice: A84041786182C187
Wolf.
can you share a screenshot of the device dashboard.
Hi to all, any updates reading the LWL02 leak sensor integration on Cayenne via Helium? The integration of sensors like LHT65 or LDD75S from Dragino are working fine, also the motion sensor from Browan PIR-1. The integration of the LWL02 on datacake is ok. My questions to the experts are: Have someone a custom decode example for the helium console available? Or any other ideas? Many thanks in advance ![]()
PS: I’m beginner … ![]()
Any updates from the Cayenne Team reading the technical integration? VG
no ![]()
Added an updated version for LWL02.
You will need to remove the current device and add the new device by selecting Dragino LWL02 LoRaWAN Water Leak Sensor V1.0 from the device list.
Please test the new device and let me know
I had the same issue with my LWL02 using v1.0 from the device list.
It only shows location but not any other information.
Devices is A84041C21184A713
i can see following data in the logs for A84041C21184A713 so it should show it in the dashboard:-
{"value":100,"name":"Battery"},
{"value":0,"name":"Water Leak"},
{"value":17,"name":"Water Leak Times"}
Thanks, it is working now. ![]()
Not sure if you changed anything but I see all the data this morning
Mmh, if I use the different integration setups with my device EUI (LWL02 Dragino), I see different network sources, like The Think Network, or Actility but not Helium. I think, the preparted device setups are looking in the wrong souces?!? Greetings … “the hope is last to die” ![]()
… that looks perfect and this is what I need. Anyway, my magic code A840417E2184672C is not working on my dashboard. Pretty crazy, regards Guido.
On Datacake is everything fine ![]()
Are you sure you need the decoder before CY?
I have just connected mine directly.
What does the debug logs say?
Dear Peter, many thanks for your reply. Your advice to check the setup on helium was a useful information. In the end, my integration on Helium was not a proper MyDevice integration. Exiting is, the data transfer of my other sensors from Dragion and Browan had no variolations. Now, everything is running. Regards, Guido.
