This is all very new to me and I’m hoping to get help, I have a normally closed switch and I only want to trigger when it changes state so I have tried the following code it won’t go online until I trigger the switch but then it goes offline if not triggered again.
#define SENSOR_PIN 12 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define VIRTUAL_CHANNEL 1
int previousState = 0;
int currentState = 1;
currentState = digitalRead(SENSOR_PIN);
CAYENNE_OUT(VIRTUAL_CHANNEL)
Cayenne.virtualWrite(VIRTUAL_CHANNEL, digitalRead(SENSOR_PIN));
previousState = currentState;
