Timed triggers
Hi guys can someone tell me how to make an actuator to be “on” for a specified time? say have an LED turn on only for 10 seconds then turn off? do we have this option when using triggers? thanks.
Using trigger this cannot be achieved. But this can be done by coding your device.
Can u show me a sample sketch on how to accomplish this?Thanks in advance
try this:
  pinMode(4, OUTPUT);
int x;
unsigned long lastMillis = 0;
  if (x == 1)
      x = 0;
      Serial.println("led is off");
      digitalWrite(4, LOW);
      Cayenne.virtualWrite(1, 0);
CAYENNE_OUT_DEFAULT()
  //Cayenne.luxWrite(2, 700);
CAYENNE_IN(1)
  x = getValue.asInt();
  lastMillis = millis();
  Serial.println("led is on");
  digitalWrite(4, HIGH);
thank u for your help. it worked!
