you need to connect it first. then restart the agent again.
fait mais aucun changement !
after restart can you share the log output?
i want the output after restart. those lines are of previous log file.
can you try install GitHub - adafruit/Adafruit_Python_PCA9685: Python code to use the PCA9685 PWM servo/LED controller with a Raspberry Pi or BeagleBone black. and run the simpletest.py code from the example folder to verify that the PCA9685 is connected properly.
ok je vais essayer demain car maintenant de dois sortir merci et bonne soirée
Bonjour ou dois je mettre le “simpletest.py” pour l’exécuter et faire l’exemple
you need to run this Adafruit_Python_PCA9685/simpletest.py at master · adafruit/Adafruit_Python_PCA9685 · GitHub and see if the servo motor works.
toujours rien je désespère
this is a sample test to check whether you have an issue with your PCA9685.
better follow this tutorial Overview | Adafruit 16 Channel Servo Driver with Raspberry Pi | Adafruit Learning System and get it working first.
