2020-03-04 09:14:45 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:296000800000’, ‘value’: 0.0, ‘type’: ‘temp’, ‘unit’: ‘c’, ‘name’: ‘DS18S20’}, {‘channel’: ‘dev:5a982c4567014ed’, ‘value’: 0, ‘type’: ‘digital_actuator’, ‘unit’: ‘d’, ‘name’: ‘Cabinet 1 Pump’}, {‘channel’: ‘dev:6d4b6b6a39204fa’, ‘value’: 0, ‘type’: ‘digital_actuator’, ‘unit’: ‘d’, ‘name’: ‘Cabinet 2 Pump’}, {‘channel’: ‘dev:c96000800000’, ‘value’: 0.0, ‘type’: ‘temp’, ‘unit’: ‘c’, ‘name’: ‘DS18S20’}]
2020-03-04 09:14:45 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 14.6}, {‘sys:cpu;temp’: 49.173}, {‘sys:ram;usage’: 622194688}, {‘sys:storage:/;usage’: 5906964480}]
2020-03-04 09:14:58 - myDevices - INFO - Temperature - DS18S20(slave=10-a96000800000) a96000800000 added
2020-03-04 09:14:58 - myDevices - INFO - 1-wire device does not exist: DS18S20, 10-c96000800000
2020-03-04 09:14:59 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:296000800000’, ‘value’: 0.0, ‘type’: ‘temp’, ‘unit’: ‘c’, ‘name’: ‘DS18S20’}, {‘channel’: ‘dev:5a982c4567014ed’, ‘value’: 0, ‘type’: ‘digital_actuator’, ‘unit’: ‘d’, ‘name’: ‘Cabinet 1 Pump’}, {‘channel’: ‘dev:6d4b6b6a39204fa’, ‘value’: 0, ‘type’: ‘digital_actuator’, ‘unit’: ‘d’, ‘name’: ‘Cabinet 2 Pump’}, {‘channel’: ‘dev:a96000800000’, ‘value’: 0.0, ‘type’: ‘temp’, ‘unit’: ‘c’, ‘name’: ‘DS18S20’}]
2020-03-04 09:14:59 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 3.3}, {‘sys:cpu;temp’: 47.225}, {‘sys:ram;usage’: 621305856}, {‘dev:a96000800000’: 0.0}]
2020-03-04 09:15:14 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:296000800000’, ‘value’: 0.0, ‘type’: ‘temp’, ‘unit’: ‘c’, ‘name’: ‘DS18S20’}, {‘channel’: ‘dev:5a982c4567014ed’, ‘value’: 0, ‘type’: ‘digital_actuator’, ‘unit’: ‘d’, ‘name’: ‘Cabinet 1 Pump’}, {‘channel’: ‘dev:6d4b6b6a39204fa’, ‘value’: 0, ‘type’: ‘digital_actuator’, ‘unit’: ‘d’, ‘name’: ‘Cabinet 2 Pump’}, {‘channel’: ‘dev:a96000800000’, ‘value’: 0.0, ‘type’: ‘temp’, ‘unit’: ‘c’, ‘name’: ‘DS18S20’}]
2020-03-04 09:15:14 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 84.0}, {‘sys:cpu;temp’: 51.608}, {‘sys:ram;usage’: 678854656}, {‘sys:storage:/;usage’: 5912174592}, {‘sys:net;ip’: ‘192.168.0.72’}, {‘dev:296000800000’: 0.0}, {‘dev:5a982c4567014ed’: 0}, {‘dev:6d4b6b6a39204fa’: 0}, {‘dev:a96000800000’: 0.0}] + sys:gpio
2020-03-04 09:15:29 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:296000800000’, ‘value’: 0.0, ‘type’: ‘temp’, ‘unit’: ‘c’, ‘name’: ‘DS18S20’}, {‘channel’: ‘dev:5a982c4567014ed’, ‘value’: 0, ‘type’: ‘digital_actuator’, ‘unit’: ‘d’, ‘name’: ‘Cabinet 1 Pump’}, {‘channel’: ‘dev:6d4b6b6a39204fa’, ‘value’: 0, ‘type’: ‘digital_actuator’, ‘unit’: ‘d’, ‘name’: ‘Cabinet 2 Pump’}, {‘channel’: ‘dev:a96000800000’, ‘value’: 0.0, ‘type’: ‘temp’, ‘unit’: ‘c’, ‘name’: ‘DS18S20’}]
2020-03-04 09:15:29 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 3.5}, {‘sys:cpu;temp’: 48.199}, {‘sys:ram;usage’: 681103360}, {‘sys:storage:/;usage’: 5907755008}]
2020-03-04 09:15:43 - myDevices - INFO - Temperature - DS18S20(slave=10-696000800000) 696000800000 added
2020-03-04 09:15:45 - myDevices - INFO - Sensors info: [{‘channel’: ‘dev:296000800000’, ‘value’: 0.0, ‘type’: ‘temp’, ‘unit’: ‘c’, ‘name’: ‘DS18S20’}, {‘channel’: ‘dev:5a982c4567014ed’, ‘value’: 0, ‘type’: ‘digital_actuator’, ‘unit’: ‘d’, ‘name’: ‘Cabinet 1 Pump’}, {‘channel’: ‘dev:696000800000’, ‘value’: 0.0, ‘type’: ‘temp’, ‘unit’: ‘c’, ‘name’: ‘DS18S20’}, {‘channel’: ‘dev:6d4b6b6a39204fa’, ‘value’: 0, ‘type’: ‘digital_actuator’, ‘unit’: ‘d’, ‘name’: ‘Cabinet 2 Pump’}, {‘channel’: ‘dev:a96000800000’, ‘value’: 0.0, ‘type’: ‘temp’, ‘unit’: ‘c’, ‘name’: ‘DS18S20’}]
2020-03-04 09:15:45 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 0.0}, {‘sys:ram;usage’: 680534016}, {‘sys:storage:/;usage’: 5907746816}, {‘dev:696000800000’: 0.0}]
