Raspberry Pi finishes setup but won’t show as set up on Cayenne
    Pi 3 B+
    Web and iOS
I removed cayenne from my pi but I wanted to reinstall it so I did and the setup completed fine but it won’t show up a set up on cayenne
can you share the output of tail -f /var/log/myDevices/cayenne.log
There is nothing in the /var/log/myDevices folder
that means the install was not successfully. can you try installing again using the terminal and see if it produces any error are produced.
It worked this time for some reason. I wonder why it didn’t work before when I did it the same way.
Thanks for the help!
