Hello everybody, Excuse me english im new, I use a node that have the RN2903a I send and recived data from Oberwise its all correct, but I need to do a sketch than only recibe downlink, for recived the response i need to send data in my sketch.
loraSendData(3, lpp.getBuffer(), 1);
if (strstr(response, "01")) {
delay(1000);
digitalWrite(PIN_LED, LOW);
debugSerial.println(response);
delay(5000);
digitalWrite(PIN_LED, HIGH);
I need that i recive the contents of “response” without send data to the gateway.
Also I tried to used the comand radio tx 0 and mac pause but I continue dont see the data that I send from oberwise
I apreccied so much you help.
which network server are you using?
are you able to get any downlink payload? the user has to handle the downlink message at the NS. With TTN, we have a downlink URL and token as part of each UplinkMessage, make it for downlink to work out the box.
I am not sure if I understand your question, I can see on the serial monitor the downlink messages of the commands such as mac get adr or the response commands of the mac tx command, in fact when I send from the Yeap module (my provider of lora services) any data for example A0 I can see it in the node, but as long as I send data to the server before, what I want to do is not have to send data to the server so that I can receive downlink.
again excuse my english I usually speak spanish.
sorry but i did not understand you. can you share the serial monitor output of the downlink message.
