Smart Brankas using RFID, Password and Motion Sensor
About This Project
Smart Brankas with high Security
early notification that can detect movement from human presence using Passive Infra Red (PIR) Sensors, password combinations and RFID
when owner/sneak try to open, the motion sensor will detect and give notification. to open the door, owner must tap the RFID, if true the system will request the Password and owner can input the password from Keypad. if the password true, Relay will LOW and the Solenoid will OPENED and send notification.
What’s Connected
ESP8266
Arduino Mega,
Motion Sensor
RFID
Keypad
LCD
Modul Relay
Solenoid Door Lock
Buzzer
Adaptor 12V.
Triggers & Alerts
Email and Text Message
When the Motion detected, ESP8266 will send notification
when Solenoid is opened, ESP8266 will send notification
Dashboard Screenshots
Photos of the Project
When Motion Sensor Detected
When Solenoid Opened
Source Code
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 53
#define RST_PIN 2
#define SENSOR_PIN 12
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
#include <Password.h> //http://www.arduino.cc/playground/uploads/Code/Password.zip
#include <Keypad.h> //http://www.arduino.cc/playground/uploads/Code/Keypad.zip
#define EspSerial Serial1
#define VIRTUAL_CHANNEL 1
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char passwordCayenne[] = "";
char clientID[] = "";
MFRC522 rfid(SS_PIN, RST_PIN); // Instance of the class
MFRC522::MIFARE_Key key;
byte nuidPICC[3];
String uid="";
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
Password password = Password( "1234" );
const byte ROWS = 4;
const byte COLS = 3;
String passKode="";
int relay = 13;
int buzzer = 32;
char keys[ROWS][COLS] = {
  {'1', '2', '3'},
  {'4', '5', '6'},
  {'7', '8', '9'},
  {'*', '0', '#'}
byte rowPins[ROWS] = { 9,8,7,6 };// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte colPins[COLS] = { 5,4,3, };// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int proses=1;
int state=0;
ESP8266 wifi(&EspSerial);
  koneksi();
  pinMode(buzzer, OUTPUT);
  digitalWrite(buzzer, LOW);
  //----------------------------------RFID
  SPI.begin(); // Init SPI bus
  rfid.PCD_Init(); // Init MFRC522
  for (byte i = 0; i < 6; i++) {
    key.keyByte[i] = 0xFF;
  pinMode(relay, OUTPUT);
  digitalWrite(relay, HIGH);
  // initialize the LCD
  lcd.begin();
  keypad.addEventListener(keypadEvent); //add an event listener for this keypad
  // Turn on the blacklight and print a message.
  lcd.backlight();
  lcd.setCursor(0,0);
  lcd.print("Selamat Datang");
  lcd.setCursor(0,1);
  lcd.print("Scan Kartu Anda");
  checkSensor();
  if(proses == 1){
    checkRfid();
  else if(proses == 2){
   keypad.getKey();
  else{
void checkRfid(){
  uid = "";
  // Look for new cards
  if ( ! rfid.PICC_IsNewCardPresent())
    return;
  // Verify if the NUID has been readed
  if ( ! rfid.PICC_ReadCardSerial())
    return;
  MFRC522::PICC_Type piccType = rfid.PICC_GetType(rfid.uid.sak);
  // Check is the PICC of Classic MIFARE type
  if (piccType != MFRC522::PICC_TYPE_MIFARE_MINI &&
    piccType != MFRC522::PICC_TYPE_MIFARE_1K &&
    piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
    return;
  if (rfid.uid.uidByte[0] != nuidPICC[0] ||
    rfid.uid.uidByte[1] != nuidPICC[1] ||
    rfid.uid.uidByte[2] != nuidPICC[2] ||
    rfid.uid.uidByte[3] != nuidPICC[3] ) {
    //Serial.println(F("A new card has been detected."));
    // Store NUID into nuidPICC array
    for (byte i = 0; i < 4; i++) {
      nuidPICC[i] = rfid.uid.uidByte[i];
    printHex(rfid.uid.uidByte, rfid.uid.size);
    printDec(rfid.uid.uidByte, rfid.uid.size);
    if(uid == "513722945"){
      digitalWrite(buzzer, LOW); //buz mati
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("Scan Sukses");
      lcd.setCursor(0,1);
      lcd.print("Masukan Password");
      delay(1000);
      proses = 2;
      passKode="";
      state = 0;
    else{
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("Kartu Salah");
      lcd.setCursor(0,1);
      lcd.print("Scan Ulang Kartu");
      digitalWrite(buzzer, HIGH);
      delay(2000);
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
  //else Serial.println(F("Card read previously."));
  // Halt PICC
  rfid.PICC_HaltA();
  // Stop encryption on PCD
  rfid.PCD_StopCrypto1();
void koneksi(){
  EspSerial.begin(115200);
  delay(10);
  Cayenne.begin(username, passwordCayenne, clientID, wifi, ssid, wifiPassword);
void keypadEvent(KeypadEvent eKey){
  switch (keypad.getState()){
  case PRESSED:
  state = state + 1;
  if(state <= 1){
    lcd.clear();
    lcd.setCursor (0,0);
    lcd.print("Tekan # ");
  else{
  lcd.clear();
  lcd.print("Password Anda :");
  if(state > 1){
  lcd.setCursor (0,1);
  passKode+="*";
  lcd.print(passKode);
  switch (eKey){
    case '*': checkPassword(); break;
    case '#':
    passKode="";
    lcd.clear();
    password.reset();
    break;
    default: password.append(eKey);
int previousState = -1;
int currentState = -1;
void checkSensor()
  if (currentMillis - previousMillis >= 250) {
    currentState = digitalRead(SENSOR_PIN);
      Cayenne.virtualWrite(VIRTUAL_CHANNEL, currentState);
      previousState = currentState;
      if(currentState ==1){
       digitalWrite(buzzer, HIGH); //buz hidup
      }else{
        //digitalWrite(buzzer, LOW);
void checkPassword(){
  if (password.evaluate()){
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Password Cocok");
    lcd.setCursor(0,1);
    lcd.print("Terima Kasih");
    digitalWrite(relay, LOW);
    Cayenne.virtualWrite(5, 1, "digital_sensor", "d");
    passKode="";
    password.reset();
    delay(3000);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Pintu Terbuka");
    delay(5000);
    lcd.clear();
    Cayenne.virtualWrite(5, 0, "digital_sensor", "d");
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    state = 0;
    proses = 1;
    //Add code to run if it works
  }else{
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Password Salah");
    delay(3000);
    state = 0;
    proses = 1;
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
void printHex(byte *buffer, byte bufferSize) {
  for (byte i = 0; i < bufferSize; i++) {
    Serial.print(buffer[i] < 0x10 ? " 0" : " ");
    Serial.print(buffer[i], HEX);
void printDec(byte *buffer, byte bufferSize) {
    Serial.print(buffer[i], DEC);
    uid += buffer[i];
int statusrelay =digitalRead(relay);
void balikKeAwal(){
  if(statusrelay == 1)
   delay(3000);
   Cayenne.virtualWrite(6, 0, "digital_sensor", "d");
   lcd.clear();
  } proses = 1;
  state = 0;
void autoLock(){
  lcd.print(F("AutoLock After"));
           for(int i=5; i>0; i--){
            lcd.setCursor (0,1); lcd.print(i);
            delay (1000);
nice project @mfajar_12 and thank you for sharing the project with the community.
thank you for helping me sir :slight_smile:
