Hi Shramik & all,
I’m trying to add a resend of the trigger notification every hour as a reminder. Thought just by resetting the widget back to 0 would do it. Everything works but the reset. Is there a better way? Any pointers?
Thanks,
John
This example is to be used when using Cayenne triggers.
Steps:
- Set the trigger and threshold values in the sketch below.
- Compile and upload the sketch.
- Two temporary widget (DATA_CHANNEL and TRIGGER_CHANNEL) will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
- Add trigger on your cayenne dashboard for the TRIGGER_CHANNEL widget when it becomes 1.
#include <OneWire.h>
#define ONE_WIRE_BUS 2
DeviceAddress tempSensorA = { 0x28, 0xFF, 0x09, 0x61, 0x51, 0x17, 0x04, 0x97};
char ssid = “__”;
char wifiPassword = “00”;
char username = “000000000000”;
char password = “0000000000”;
char clientID = “000000000”;
#define DATA_CHANNEL 0 //Virtual channel for publishing sensor data.
#define TRIGGER_CHANNEL 1 //Virtual channel for publishing the trigger value.
#define THRESHOLD 75 //Threshold for the trigger.
unsigned long lastMillis = 0;
bool sendBelowThreshold = false; ///// Set to true if the trigger should happen when the data value is below the threshold,
///// false if it should happen when the data value is above or equal to the threshold.
bool crossedThreshold = false;
int previousState1 = -1;
int currentState1 = -1;
sensors.setResolution(tempSensorA, 10);
sensors.begin();
void sendTriggerValue(int channel, int value, int threshold, bool sendBelowThreshold) {
if (((value >= threshold) && !sendBelowThreshold) || ((value < threshold) && sendBelowThreshold)) {
if (!crossedThreshold) {
Cayenne.virtualWrite(channel, 1, “digital_sensor”, “d”); //set trigger two-state widget to 1
crossedThreshold = true;
else
Cayenne.virtualWrite(channel, 0, “digital_sensor”, “d”); //set trigger two-state widget to 0
//Publish data every 5 minutes (300000 milliseconds).
if (millis() - lastMillis > 60000)
lastMillis = millis();
int sensor_value1 = sensors.getTempF(tempSensorA);
sendTriggerValue(TRIGGER_CHANNEL, sensor_value1, THRESHOLD, sendBelowThreshold);
Cayenne.virtualWrite(DATA_CHANNEL, sensor_value1 , “temp”, “f”);
long rssi = WiFi.RSSI();
Cayenne.virtualWrite(3, rssi, "rssi", "dbm");
// Problem here>>>>>>>
// Reset trigger every 1 hour (3600000 milliseconds).
if (millis() - lastMillis > 120000)
Cayenne.virtualWrite(1, 0, "digital_sensor", "d"); //set trigger two-state widget to 0
