Unable to create LoRa ThingsNetwork Device in Cayenne https://cayenne.mydevices.com/cayenne/dashboard/add. Though device UI is unique and no device is existing in this cayenne account, i am unable to create device with following error.
Do you already have this device registered on your account? If so delete it and it should work. If not @shramik_salgaonkar should be able to help you remove it from wherever it’s being used.
I had a Bosch XDK110 device with different device EUI already registered. That was working.
When i tried to register a new XDK110 device with unique device EUI (different from previous), i get the mentioned “conflict” error.
I deleted the old device and still error persists.
After waiting for a day also, registration does not succeed.
Also the error is not informative, since it does not show which field causes this error!
