Just tested my educational template for ‘Penguin Crossing’ (Zebra Crossing) that uses:
pins 19,21,23 = R,Y,G LEDs
pin 18 = Piezo 3 Volt buzzer
Pins 24,26 = ‘Call Buttons’ from either side of the street
The default Pi / Rasparian Epiphany web browser did not work but IceWeasel installed from terminal on the desktop and ran nicely.
Thanks !
(first) Questions:
What is ALT0 (presume initial state of Pi / WebIOPi pin state on boot ?)
Is the UART on the GPIO ttyAMA0 already set up or are the usual tweakes needed to the boot and Getty ?
Will do if I see it again… Suspect may be slowwwwwwwwness of things here ‘down under’
I have a student coming in to set up some boxes for looking at things / gui displays on a range of OS
~ Andrew
@svazir andrew’s issue is related to SPI/I2C enabled in Raspberry Pi but not using it.
Would be solved by fixing I2C/SPI setting in the Pi configuration from the dashboard.
