Hi, this is probably a noob question, but it seems I am stuck. I have a working Dragino LSN50 with a temp sensor registered to TTN. In the TTN console I have activated the MyDevices integration and on mydevices.com I have registered my node:
Device > Lora > the things network > Dragino Technology LoRa Sensor Node-LSN50 > entered my DevEUI
Then I copied the key from the URL into the Mydevices integration on TTN
I have been waiting for a few hours now, but nothing happens. What have I overlooked? I can see the data flowing on the TTN console with measurements etc.
Thank you, Shramik. Probably not. I read about this payload and libraries for the Arduino but I am not aware that I need to do something for the Draguino LSN50. How do I do that?
Yes, this is the node. It worked with TTN out of the box; no need to program anything. I just had to add a payload converter supplied by the factory in TTN
I had similar problems with a RAK7204 environment sensor. For me, what finally fixed it (after I had overcome the very poorly documented “Process ID” hurdle, and set an appropriate payload format) was resetting the frame counter on the device in TTN.
Same situation here. Using LSN50 v2 registered in TTS. As recommanded by TTS I specify Cayenne LPP payload format rather then the genuine LSN50 in the devices proposal. No Data received after several hours.
