io.reactivex.exceptions.OnErrorNotImplementedException: Attempt to invoke virtual method ‘boolean java.lang.String.contains(java.lang.CharSequence)’ on a null object reference
at io.reactivex.internal.functions.Functions$OnErrorMissingConsumer.accept(Functions.java:704)
at io.reactivex.internal.functions.Functions$OnErrorMissingConsumer.accept(Functions.java:701)
at io.reactivex.internal.observers.LambdaObserver.onError(LambdaObserver.java:77)
at io.reactivex.internal.observers.LambdaObserver.onNext(LambdaObserver.java:67)
at io.reactivex.internal.operators.observable.ObservableMaterialize$MaterializeObserver.onNext(ObservableMaterialize.java:62)
at io.reactivex.internal.operators.observable.ObservableDoOnEach$DoOnEachObserver.onNext(ObservableDoOnEach.java:103)
at io.reactivex.internal.operators.observable.ObservableObserveOn$ObserveOnObserver.drainNormal(ObservableObserveOn.java:200)
at io.reactivex.internal.operators.observable.ObservableObserveOn$ObserveOnObserver.run(ObservableObserveOn.java:252)
at io.reactivex.android.schedulers.HandlerScheduler$ScheduledRunnable.run(HandlerScheduler.java:119)
at android.os.Handler.handleCallback(Handler.java:754)
at android.os.Handler.dispatchMessage(Handler.java:95)
at android.os.Looper.loop(Looper.java:163)
at android.app.ActivityThread.main(ActivityThread.java:6378)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:901)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:791)
Caused by: java.lang.NullPointerException: Attempt to invoke virtual method ‘boolean java.lang.String.contains(java.lang.CharSequence)’ on a null object reference
at com.mydevices.cayenne.presenters.model.DashboardWidgetsFactory.getDashboardWidget(DashboardWidgetsFactory.java:64)
at com.mydevices.cayenne.utils.WidgetUtils.widgetFromState(WidgetUtils.java:90)
at com.mydevices.cayenne.utils.WidgetUtils.widgetsFromWidgetStates(WidgetUtils.java:351)
at com.mydevices.cayenne.activities.home.DeviceActivity.updateWidgets(DeviceActivity.java:297)
at com.mydevices.cayenne.activities.home.DeviceActivity.lambda$receivedSystemInfo$0(DeviceActivity.java:285)
at com.mydevices.cayenne.activities.home.-$$Lambda$DeviceActivity$7LZdqqIdD5y-Z9vFhCcyU4jMGz4.accept(lambda)
at io.reactivex.internal.observers.LambdaObserver.onNext(LambdaObserver.java:63)
… 12 more
can you provide more details
can you direct message me your email_id
I have sent it to you
1.5.10-107 working perfect. You can close the topic
glad to hear it is working now.
