kjbovl
Hi
I am experimenting with Lorawan and got me some sensors and a Dragino LT22222, which i want to use the outputs on to be activated by triggers.
Unfortunately i can not click on the SAVE-buttom in the trigger-section.
Is it limitations on the free-user-account? Or am I doing something wrong?
Regards
Kaj
can you share a screenshot of the trigger you are trying
kjbovl
3
I did try once more. And this time it would save the trigger.
Can I ask you anotherthing; Can you make a double test in IF-statments? like IF (a>10 and b=1 ) then…
So do AND, OR and so on apply in Cayenne trgiggers?
this is not supported in cayenne.
kjbovl
5
Thanks for your answer. I will continue to play with the triggeres. Perhaps I can work my way around it?
