Barometer on Web Dashboard not showing historic data
Hi I’m running a PyComm LOPY4 and I successfully had all my sensors reporting correctly on the Web Dashboard.
I have noticed recently that my Barometer reading is showing the correct value, but when you check any historic information is says no data is available.
I have checked the data received by Cayenne Web Dashboard and it clearly shows the values over a period of time.
I’m unsure how to proceed as I know the data is being received and logged on the Web Portal, but not processing it.
Many Thanks
can you private message me your DevEUI, so that i can check what is the issue.
Have send you a PM with my DevEUI have you been able to investigate?
please check your inbox.
