I tried to use the cayenne integration with my Wistrio Rak5205 Board that I registered in the “thingpark” from swisscom / activity.
Right now I’m having the problem that I can’t add the device to Cayenne because I get the error:
Please fix the following errors:
When creating the device but from what I’ve read here that’s a caching problem on your side that happens when a recently deleted device gets added with the same DevEUI and should go away in ~1 hour.
Did you ever recieve any data from the DevEUI “60C5A860C5A83534”?
Kind regards
Matthias Weissen
we have received data for this DevEUI.
Thanks for your fast respond!
Is there anyway to surpass the described error?
Kind regards
is it still happening? can you try adding it now.
It was still happening yeah but it worked 10 minutes ago so the device is added now!
The problem is now that I don’t get Cayenne to show any data.
What data-format does cayenne require? Is it XML, JSON or JSON untyped?
Kind regards
the payload need to be in cayenne LPP payload format Cayenne Docs
Sorry for phrasing my question so bad.
I meant the content-type that I have to define in the Thingpark Web-Interface.
Because I can see that the data reaches my defined application-server and I also checked the link "
https://lora.mydevices.com/v1/networks/swisscom/uplink" which should be correct.
So the only thing that I can change is the content-type where I have to choose between “XML, JSON, JSON untyped”
Kind regards
