hello,
I’m getting closer to your world. I configured my dragino with TTN and then with cayenne. It works, but I immediately noticed a first “problem”: I connected to the AVI1 input the same power cable of the dragino (12Volt DC).
the data I see on cayenne is: 125.44000244141 Volt
The error is one decimal place!
the correct value would be: 12.544000244141 Volt
Considering that on TTN as decoder payload I used “Cayenne LPP”, how can I correct errors of this type directly on CAYENNE?
are you getting the correct value on your TTN console?
PAYLOAD FROM TTN:
0000 0000 3102 0000 38
From the Dragino user manual on page 11 I find the information to infer the tension:
AVI1 is 0x3102/1000=12,546V
So I assume the TTN data is correct. Do not you think?
can you share the user manual link.
I am also using the Dragino LT-33222-L. TTN shows the correct value on my voltage input 1 as 8.939V, but Cayenne desktop shows 89.39V.
I am using the Dragino LPS8 (LG08) gateway with version LG02_LG08-5.3.1576467023 firmware.
can you private message me your devEUI.
