I’m using a Dragino LSE01 and Dragino LG02 (setup via TTN) and want to integrate the sensor values in cayenne to use the widgets. Data is transmitted, but the conductivity value is a hundredth of its actual value. Also the unit is shown in cayenne as “null”, but it should be “uS/cm”. The unit issue occurs with the soil temperature in a similiar way, showing “p” instead of “c”. The value of the soil temperature is correct.
In the beginning i set the payload format to custom and used Dragino’s decoder. After some research, i changed it to Cayenne LPP, which didn’t change anything.
I’m also using a Dragino LHT65, which is working fine in Cayenne with Dragino’s decoder set in the payload format in TTN.
Hope you can help me find the error.
