Am working on a porject to alert a user when humidity reaches 50. How can I do that
below is my code.
CAYENNE_OUT(2)
float hum=dht.readHumidity();
Serial.println(“Humi is”);
Serial.println(hum);
Cayenne.virtualWrite(2, hum );
below is my code.
CAYENNE_OUT(2)
the code to send data within limit is quite simple. You need to understand how a function works and how we can pass parameters. Go through this link on how functions work https://www.arduino.cc/en/Reference.FunctionDeclaration#:~:text=There%20are%20two%20required%20functions,function%20to%20multiply%20two%20numbers.
So below are the parameters or data you want to pass in the function
#define TRIGGER_CHANNEL 1
#define THRESHOLD 200
bool sendBelowThreshold = true;
now you need to pass it in the function
sendTriggerValue(TRIGGER_CHANNEL, sensor_value, THRESHOLD, sendBelowThreshold);
and that’s all, when the sensor_value is below the threshold (if you have set sendBelowThold as true) then it will send the data to a two-state widget.
Then the trigger I make is based on the two state widget?
yes. since you are making the two-state widget data 1 which implies that the sensor_value has crossed the threshold value.
meaning I will trigger the two state widget. if threshold is 50 and sendBelowThreshold = true;
then it will be triggered when its off?
Is it possible for someone to edit the notification sent by trigger
i did not understand this.
this is an old post, and I guess IFTTT has discontinued the service. You can try the alternate services Webhook And IFTTT
