Raspberry Pi 3 -
Web - This works fine
IOS App - crashes on button press (Relay) -
I have several relays configured within Cayenne. This works flawlessly on the Webapp however after upgrading last night the IOS App crashes as soon as i press a button.
Each button is linked to a Solid State Relay.
I notice on the web app the channel shows as “dev:LKMEyzrzELGMsnH” instead of just the channel number. Nor do I have the ability to change the channel.
