I’m using a LoRaButton RAK LB801 to connect to TTN through a Dragino gateway using LoRaWan protocol.
but when i tried to make an OTAA join it failed, it just say “Fail” when i execute the “at+join=otaa”
i already check the logs on the gateway and they are empty, but the configuration seems alright
here is an image with the configuration
so please any idea about why the gateway doesn’t receive the button signal even though it’s online is very much appreciated
