Netvox Trigger not working
I have added trigger but not working for both siren/sms/email.
can you delete the temperature widget and the trigger. Let the temp widget, re-add on next uplink. once done, try adding the trigger again.
Same (no trigger). This round only can select unit (Celcius).
the trigger has run now. you can check the trigger counter on the trigger page. it has incremented to 4.
Did you check the TTN dashboard if you have received the downlink.
Sorry. I do not have access to TTN due to uploaded by Netvox directly, as I am In-a-box whitelabel user.
can you private message me your account details.
