Installing myDevices on a Pi3 running Raspbian Stretch. I have installed on other devices with the same configuration with no errors.
Output of the installer ends with:
Installed /usr/local/lib/python3.5/dist-packages/myDevices-2.0.3-py3.5.egg
Processing dependencies for myDevices==2.0.3
Searching for psutil>=0.7.0
Reading https://pypi.org/simple/psutil/
Downloading https://files.pythonhosted.org/packages/2f/b8/11ec5006d2ec2998cb68349b8d1317c24c284cf918ecd6729739388e4c56/psutil-5.6.1.tar.gz#sha256=fa0a570e0a30b9dd618bffbece590ae15726b47f9f1eaf7518dfb35f4d7dcd21
Best match: psutil 5.6.1
Processing psutil-5.6.1.tar.gz
Writing /tmp/easy_install-8otdsl8j/psutil-5.6.1/setup.cfg
Running psutil-5.6.1/setup.py -q bdist_egg --dist-dir /tmp/easy_install-8otdsl8j/psutil-5.6.1/egg-dist-tmp-qj_aspsm
Sun Mar 17 09:50:08 CDT 2019 Build for Python 3.5.3 failed
/var/log/myDevicesSetup ends with the following:
- normalEcho ‘Trying to install myDevices for python3 version: Python 3.5.3’
++ date - echo ‘Sun Mar 17 09:49:10 CDT 2019 Trying to install myDevices for python3 version: Python 3.5.3’
- python3 setup.py install --force --record /etc/myDevices/uninstall/installed_agent
zip_safe flag not set; analyzing archive contents…
myDevices.utils.pycache.logger.cpython-35: module MAY be using inspect.getouterframes
arm-linux-gnueabihf-gcc: internal compiler error: Segmentation fault (program collect2)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-6/README.Bugs> for instructions.
error: Setup script exited with error: command ‘arm-linux-gnueabihf-gcc’ failed with exit status 4 - ‘[’ 1 -ne 0 ‘]’
- normalEcho ‘Build for Python 3.5.3 failed’
++ date - echo ‘Sun Mar 17 09:50:08 CDT 2019 Build for Python 3.5.3 failed’
- exit 1
It’s a fairly recent install of the OS, but I will update and try again. I have not opened a bug report on gcc just yet. Thought I would pursue this route first.
Any ideas?
Thanks,
-Brian
