What does it mean - error message
Problem sending command: Invalid UbiQ DASS URL
when trying to sent downlink from dashboard of LoRa custom device connected via Orbiwise?
I’m using Digital output widget.
can you share a screenshot of the error on the dashboard.
which Network server have you connected to?
Yes, I’ve selected Add New Device → LoRa - > Orbiwise → Cayenne LPP, entered orbiwise server mentioned above and my credential for it…
can you PM me your email_id.
Thank you so much - that helped, i’m very grateful for Your collaboration.
Would You be so kind to explain one more thing - is it necessary to use MQTT for lora device or Cayenne LPP is enough?
