Remote desktop and data history for system widgets are discontinued. mobile app now supports pi agents 2.0
any deadline for when pca9685 can be add for Rpi3 ?
Do i have to reinstall cayenne ? Because it says : you have no capable devices
Yes, you must have the cayenne Pi agent 2.0 installed
I have 2.0.1.255 installed on my raspberry pi 3
But can’t add my pca9685
Can you post the output?
Output?
It worked before agent 2.0
cd /etc/myDevices/plugins
sudo git clone https://github.com/myDevicesIoT/cayenne-plugin-pca9685.git
sudo service myDevices restart
I will do that tomorrow, and see if it works
i just installed a clean rasbian on a rpi 3, with pca9685 attach , and did that in terminal, but i cant still add it to my pi
there is a new plugin for PCA9685 GitHub - myDevicesIoT/cayenne-plugin-pca9685: A PCA9685 plugin for Cayenne it will auto add the slider widget to your dashboard when added.
@dyna2000cctv if you go to the device on the cayenne dashboard that you ran those commands on you should see the widgets available to you now. Add new>device/widget>extensions is broken right now.
I am a bit confused looking at the time stamps of the posts, is support for the PCA9685 in the system or not. I am unable to add it to through the extensions portion of the web app. Grayed out boxes do not allow me to add it. What am I missing here, I have read through the threads and nothing is telling me this is solved or this is a solution. Please help
i guess you not gone through the post in this topic. Have a look at this post.
Thank you for your response, I had gone through this post and I have the sliders for the channels showing up but I have no control, when I go to add the controller PCA9685 it will not allow me to do so, not sure if I need the controller added via Cayenne interface. Please help I have triple checked my wiring, I have 5volts going to the PCA9685, thank you in advance for your help. I have showing in my control panel in the application PCA9685_CH0-15
What are you controlling using the pca9685. The slider that are shown on youe dashboard on adding pca9685 plugins are to send raw data to pca9685 channel.
I am wanting to control servos utilizing the pca9685
