change this in the code:
#define RST_PIN D3 // Configurable, see typical pin layout above
#define SS_PIN D8
#define SS_PIN D8
now place your UID on the reader
hago lo mismo en el codigo cayenne?
[quote=“riegosnaturales, post:45, topic:5674”]
[/quote] ya estan definidos d3 y d8 en cayenne_rfi_ donde es el lugar correcto para pegar los renglones que me enviaste ayer?
try this code as you are getting some error.
#include <SPI.h>
#include <MFRC522.h>
constexpr uint8_t RST_PIN = D3; // Configurable, see typical pin layout above
constexpr uint8_t SS_PIN = D8; // Configurable, see typical pin layout above
MFRC522 rfid(SS_PIN, RST_PIN); // Instance of the class
MFRC522::MIFARE_Key key;
// Init array that will store new NUID
byte nuidPICC[4];
Serial.begin(115200);
SPI.begin(); // Init SPI bus
rfid.PCD_Init(); // Init MFRC522
for (byte i = 0; i < 6; i++) {
key.keyByte[i] = 0xFF;
Serial.println(F("This code scan the MIFARE Classsic NUID."));
Serial.print(F("Using the following key:"));
printHex(key.keyByte, MFRC522::MF_KEY_SIZE);
// Look for new cards
if ( ! rfid.PICC_IsNewCardPresent())
return;
// Verify if the NUID has been readed
if ( ! rfid.PICC_ReadCardSerial())
return;
Serial.print(F("PICC type: "));
MFRC522::PICC_Type piccType = rfid.PICC_GetType(rfid.uid.sak);
Serial.println(rfid.PICC_GetTypeName(piccType));
// Check is the PICC of Classic MIFARE type
if (piccType != MFRC522::PICC_TYPE_MIFARE_MINI &&
piccType != MFRC522::PICC_TYPE_MIFARE_1K &&
piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
Serial.println(F("Your tag is not of type MIFARE Classic."));
return;
if (rfid.uid.uidByte[0] != nuidPICC[0] ||
rfid.uid.uidByte[1] != nuidPICC[1] ||
rfid.uid.uidByte[2] != nuidPICC[2] ||
rfid.uid.uidByte[3] != nuidPICC[3] ) {
Serial.println(F("A new card has been detected."));
// Store NUID into nuidPICC array
for (byte i = 0; i < 4; i++) {
nuidPICC[i] = rfid.uid.uidByte[i];
Serial.println(F("The NUID tag is:"));
Serial.print(F("In hex: "));
printHex(rfid.uid.uidByte, rfid.uid.size);
Serial.println();
Serial.print(F("In dec: "));
printDec(rfid.uid.uidByte, rfid.uid.size);
Serial.println();
else Serial.println(F("Card read previously."));
// Halt PICC
rfid.PICC_HaltA();
// Stop encryption on PCD
rfid.PCD_StopCrypto1();
* Helper routine to dump a byte array as hex values to Serial.
void printHex(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], HEX);
* Helper routine to dump a byte array as dec values to Serial.
void printDec(byte *buffer, byte bufferSize) {
Serial.print(buffer[i], DEC);
felicidades que buen trabajo si ha leído todas mis tarjetas te lo agradezco mucho ahora ire a buscar un sensor de lluvia para una tarjeta sw5100 espero encontrarla pronto
saludos amigo
Now that you have the UID of each RFID , you need to add my project code.
si lo quiero donde lo encuentro
Libre de virus. www.avast.com
what are you referring to?
Thank sir, i really appreciate your effort, cause i try it work perfect but the channel does not start which 0
not sure what you are sending but those value looks odd, can you share the code.
#define CAYENNE_DEBUG
char ssid = “”;
char wifiPassword = “”;
char username = ";
char password = “”;
char clientID = “”;
#include <SPI.h>
#include <EEPROM.h>
#define SS_PIN D8 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
String read_rfid;
String ok_rfid_1 = “c25b661a”;
String ok_rfid_2 = “b0eee9a9”;
String ok_rfid_3 = “c293231a”;
String ok_rfid_4 = “b2a8741a”;
//String ok_rfid_2=“b28d6d1a”; //add as many as you need.
unsigned long lastMillis = 0;
int a;
int b;
int c;
int d;
int EEaddress0 = 1;
int EEaddress2 = 4;
int EEaddress4 = 8;
int EEaddress6 = 12;/*
Initialize.
EEPROM.begin(32);
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
mfrc522.PCD_Init(); // Init MFRC522 card
a = EEPROM.get(EEaddress0, a);
Serial.println(a);
b = EEPROM.get(EEaddress2, b);
Serial.println(b);
c = EEPROM.get(EEaddress4, c);
Serial.println(c);
d = EEPROM.get(EEaddress6, d);
Serial.println(d);
Serial.println(“connected”);
pinMode(D4, OUTPUT);
void dump_byte_array(byte *buffer, byte bufferSize) {
read_rfid = “”;
read_rfid = read_rfid + String(buffer[i], HEX);
void check1() {
a++;
Serial.println(a);
EEPROM.put(EEaddress0, a);
EEPROM.commit();
digitalWrite(D4, LOW);
delay(2000);
void check2() {
b++;
Serial.println(b);
EEPROM.put(EEaddress2, b);
EEPROM.commit();
delay(2000);
void check3() {
c++;
Serial.println(c);
EEPROM.put(EEaddress4, c);
EEPROM.commit();
delay(2000);
void check4() {
d++;
Serial.println(d);
EEPROM.put(EEaddress6, d);
EEPROM.commit();
delay(2000);
digitalWrite(D4, HIGH);
lastMillis = millis();
Cayenne.virtualWrite(0, a);
Cayenne.virtualWrite(1, b);
Cayenne.virtualWrite(2, c);
Cayenne.virtualWrite(3, d);
//Cayenne.luxWrite(2, 700);
Serial.println(“reading”);
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
if (read_rfid == ok_rfid_1) {
check1();
if (read_rfid == ok_rfid_2) {
check2();
if (read_rfid == ok_rfid_3) {
check3();
if (read_rfid == ok_rfid_4) {
check4();
that is the exact same code i used, not sure why are those values.
what i would suggest is, see if can get the RFID code and eeprom code to work individually without the cayenne code.
ok, Sir
i try it is work prefect, but if i connect it with cayenne it show that value and if i swap my card/tag is increasing ( my problem how to remove that value)
thank u sir once again
Sir this is the serial output
not sure, what you are doing but how do you come to know that the value is incrementing?
example if the value is 1949655883 ,if i swap my registered card/tag it will increase to 1949655884 the more i swap my my tag the more it increase.
how can i make it to start from 0
