Hello
I am trying to integrate my ttn device with the cayenne mydevice portal.
I have a Adeunis Motion device that is connected to TTN correctly. I am able to see the messages on the TTN console.
I have set a an integration with mydevice at the TTN application level.
The integration process is at “running” status on the TTN console.
I have created the device on the Mydevice portal side as well with the following information:
Device name : Adeunis Smart Building MOTION LoRaWAN
DevEUI : 0018B260000000B9
Network: The Things Network
At the mydevice console, i have the device located on the map, SSR and RSSI values but no data visible.
What should I do to make the data visible ?
Thanks in advance for your help.
Best regards
Jean-Guillaume
can you share the sensor data payload received on the TTN console.
hello shramik
thank you for your help.
exemple of a message payload:
5C00000063
and decoded with Adeunis decoder
“decodingInfo”: “values: [t=0, t-1, t-2, …]”,
“luminosity”: {
“unit”: “%”,
“values”: [
99
“presence”: {
“unit”: “%”,
“values”: [
“presenceDetectedWhenSending”: false,
“status”: {
“configurationDone”: false,
“configurationInconsistency”: false,
“frameCounter”: 0,
“hardwareError”: false,
“lowBattery”: false
“type”: “0x5c Motion data”
Is it what you are looking for ?
Best
Jean-Guillaume
@jglalanne we made some changes, can you delete the device, wait for some time and add it again.
Very cool. It works perfectly now !
thank you very much
BR
