Dear shramik,
Thank you for replying. I have checked the latest reading, on TTN it displays:
“analog_in_4”: 68.98,
“analog_in_5”: 6.38,
“temperature_1”: 18,
“temperature_2”: 16,
“temperature_3”: 26
“time”: “2019-10-24T18:15:20.324049191Z”,
“frequency”: 868.5,
“modulation”: “LORA”,
“data_rate”: “SF7BW125”,
“coding_rate”: “4/5”,
“gateways”: [
“gtw_id”: “eui-b827ebfffeasdf”,
“timestamp”: 514682067,
“time”: “2019-10-24T18:15:20.309301Z”,
“channel”: 2,
“rssi”: -70,
“snr”: 5.8,
“rf_chain”: 1,
“latitude”: 48,
“longitude”: 11.56,
“altitude”: 300
On mydevices it displays:
2019-10-24 8:15:21
Ground sensor v1
Temperature (1)
0264cdf0-f3e2-11e9-84bb-8f71124cfdfb
temp
c
18
2019-10-24 8:15:21
Ground sensor v1
3
Temperature (3)
026c20f0-f3e2-11e9-8221-599f77add412
temp
c
26
2019-10-24 8:15:21
Ground sensor v1
2
Temperature (2)
026bf9e0-f3e2-11e9-a4a3-7d841ff78abf
temp
c
28
2019-10-24 8:15:21
Ground sensor v1
5
Analog Input (5)
0251e230-f3e2-11e9-a4a3-7d841ff78abf
analog_sensor
null
3.3299999237061
2019-10-24 8:15:21
Ground sensor v1
3
Temperature (3)
temp
c
39
2019-10-24 8:15:21
Ground sensor v1
101
SNR
024c8b00-f3e2-11e9-8221-599f77add412
snr
db
5.8000001907349
2019-10-24 8:15:21
Ground sensor v1
5
Analog Input (5)
analog_sensor
null
6.3800001144409
2019-10-24 8:15:21
Ground sensor v1
Temperature (1)
temp
c
25
2019-10-24 8:15:21
Ground sensor v1
100
RSSI
02573960-f3e2-11e9-8221-599f77add412
rssi
dbm
-70
2019-10-24 8:15:21
Ground sensor v1
2
Temperature (2)
temp
c
16
2019-10-24 8:15:21
Ground sensor v1
4
Humidity (4)
0266a2b0-f3e2-11e9-b49d-5f4b6757b1bf
analog_sensor
null
68.980003356934
2019-10-24 8:15:21
Ground sensor v1
4
Humidity (4)
analog_sensor
null
56.159999847412
2019-10-24 8:15:21
Ground sensor v1
2
Temperature (2)
temp
c
38
2019-10-24 8:15:21
Ground sensor v1
Temperature (1)
temp
c
33
