is it possible to add free text to widgets to separate the smart home or iot zones? It is also possible to make a simple alarm indicator for visual notification.Very much missing.
can you provide more info on both. i could not understand what you want.
custom text widgets only are not available, not sure why you want a text widget. you can change the name of the widget to whatever you want.
For alarm you mean to show the time or to set a schedule for an actuator?
I have temperature sensors , when the temperature rises, there should be a visual notification in the form of colors, I found only an indicator
Gauge Display Widget. there are 3 colors but it doesn’t work well in the phone.
you can use a two state widget which have change colour when the condition becomes true.
this is a known issue, and hence it is advisable to use the web dashboard for the gauge widget.
2 State Widget?
try Cayenne.virtualWrite(VIRTUAL_CHANNEL, currentState, "digital_sensor", "d");
where currentState state can be either 1 or 2. this is two state widget.
