Hi, i have a Dragino LSN50 v2-D23 (3 Temp Probes) in TTNv3 and i can see the Payload in TTN.
When i add LoRa → The Things Network → “Dragino Technology LoRa Sensor Node-LSN50” or “Dragino LSN50 v1.6+ LoRaWAN Sensor” it shows only two Temp Probes in Cayenne.
Is it possible to add support for the “Dragino LSN50 v2-D23” in Cayenne?
Thanks!
Olly
Hi, i no longer need the support for the LSN50 v2-D23 , I solved the temperature monitoring with mysql & php, that currently suffices my needs.
